Blinker replace with mini blinker
hi there
the big standard honda blinkers have just one cable. i saw that all of the mini blinkers have two separate cables. do i just have to connect one wire with the frame or how is this supposed to be done?
thanks for your advice!
ran87- Nombre de messages : 11
Re: Blinker replace with mini blinker
Hi, Do you mean this???
If it is there are two pins also! ad it's a standart Honda.
Pascal
Pascal
no, i mean this:
on the mini blinker-indicators are always two wires. i am not sure where to put the second one.
Salut Bosco !
Je pense que le gars s'est trompé de forum...
Il veut faire dans la customisation, pas dans la restauration.
Yes!!!!! ok, it's not a problem. On Honda, the two wires are ; 1) a blue wire or a orange . 2) a black wire which is the ground wire.
On yours blinkers, ther is only one wire, the ground is made by contact of the blinker on the frame.
Pascal
Pascal
Salut Eldorado,
C'est ma foi bien possible...en fait il ne comprend pas pourquoi sur les repros il ,'y a qu'un seul câble qui sort des clignos... c'est pas grave, la masse est faite par contact des clignos sur le cadre...
okay, thank you bosco!
as i tought it goes on the frame. so i will go ahead and buy this blinker-indicators .
you helped a lot!
i will show you guys the bike in a few days.
cheers
you helped a lot!
cheers
OK, great!! So I wait for your pictures!!!
Have a nice day,
Pascal
Have a nice day,
Pascal
» CG125 1982 fuel tank replace
» 30 ans plus tard!
» Mini mini !
» Mini compteur
» Construction mini bike 6,5cv
» 30 ans plus tard!
» Mini mini !
» Mini compteur
