CG125 1982 fuel tank replace
Message  ran87 le Mar 17 Fév - 0:08
hi!
i am from switzerland and found this amazing forum Smile!
already have one question: i have a honda cg 125 and need to replace the fuel tank. i found one that i like even a bit more than the original:
http://m.ebay.com/itm/111100544444?_mwBanner=1
do you guys think this one will also fit my 1982 model?
cheers and thanks for the kind help!
ran87
Nombre de messages : 11
Re: CG125 1982 fuel tank replace
Message  cbx le Mar 17 Fév - 9:42
Hello Ran87;
In France, we can't see this tank because Ebay return :
" Unfortunately, access to this particular item has been blocked due to legal restrictions in some countries. We are blocking your viewing in an effort to prevent restricted items from being displayed. Regrettably, in some cases, we may prevent users from accessing items that are not within the scope of said restrictions because of limitations of existing technology. Please accept our apologies for any inconvenience this may cause, and we hope you may find other items of interest on eBay."
Crying or Very sad
Nombre de messages : 2085
Message  ran87 le Mar 17 Fév - 9:46
Sad
okay, here is the picture:
it says "Fitment: Honda CG125 (1994-Present)". but i guess it could fit also on older models right?
ran87
Message  cbx le Mar 17 Fév - 10:06
Sorry, i don't kown Embarassed
I translate your question for "the others" ::
Salut à tous,  je traduis la question de Ran87
Un réservoir de CG de 1994 peut -il s'installer sur un CG de 1982 ??
Message  Modif13 le Mer 11 Mar - 14:11
Hello Ran 87 cheers .
I raise the subject.
This is not the same attachment to the rear of the tank. On models until April 1985 the tank is maintained at the rear by a rubber support.
On models following it is screwed to the rear on a frame holder , a silent block is located between the screw and the reservoir .
There may be a possibility to adapt ?
Thank you to inform us of the suite.
Can you make a small presentation of your bike and its driver?
See you soon.
En Français maintenant:
Bonjour Ran87 cheers .
Je relance le sujet.
Ce n'est pas la même fixation à l'arrière du réservoir. Sur les modèles jusqu'à avril 1985 le réservoir est maintenu à l'arrière par un support en caoutchouc.
Sur les modèles suivants il est vissé à l'arrière  sur un support du cadre, un silentblock se trouve entre la vis et le réservoir.
Il y a peut-être une possibilité d'adapter?
Merci de nous informer de la suite.
Peux-tu nous faire une petite présentation de ta moto ainsi que son conducteur?
A bientôt.
Nombre de messages : 882
Message  ran87 le Ven 13 Mar - 11:17
i ordered the tank. unfortunately it doesent fit on the first try but after a litte bending of the whole tank i could finally fit it on the frame. the mounting was the same as the old cg-tank...
sadly the tank got a little bump on the right side. i think this is caused of bad post-handling.
here you can see my bike so far and the fresh made colour:
ran87
Message  cbx le Ven 13 Mar - 12:04
Hello;
Bad luck with this tank Sad
Pretty bike !!
Message  Modif13 le Ven 13 Mar - 15:38
Hello Ran87
Petite traduction:
J'ai commandé le réservoir . Malheureusement il ne peut pas être fixé au premier essai , mais après un petit pliage au niveau du trou de fixation, j'ai enfin pu le monter sur le cadre . Le montage est le même que l'ancien réservoir de CG ...
Malheureusement le réservoir a une petite bosse sur le côté droit . je pense que ce est dû à une mauvaise manipulation .
Ici vous pouvez voir ma bécane et la couleur refait récemment :
ran87 a écrit:i ordered the tank. unfortunately it doesent fit on the first try but after a litte bending of the whole tank i could finally fit it on the frame. the mounting was the same as the old cg-tank...
Beautiful bike! cheers
Good luck for the future , we expect photos of the whole. bounce
See you soon
Belle bécane! cheers
Bon courage pour la suite, nous attendons les photos de l'ensemble. bounce
A bientôt
Message  ran87 le Ven 10 Avr - 11:17
Next steps:
- seat
- backlight
- front-fender
- wiring
Smile
ran87
Message  ran87 le Lun 20 Avr - 11:03
alright, this is the finished bike. hope you guys like it.
i am planning some modifications on the rear part of the bike. but first i will drive it a few weeks Wink.
thanks for your help guys!
ran87
Message  professeurhammond le Lun 20 Avr - 13:13
Hi !
Fast and clean job, I enjoy it Very Happy
Are the rear turn indicators the same as front ones ? Leds or classic bulbs ?
Cheers,
Message  ran87 le Lun 20 Avr - 13:18
Thank you!
Yes, they are the same one's. Small 12V bulbs...
http://www.polo-motorrad.ch/de_ch/blinker-peak-21w-schwarz-langer-arm.html (just black & short, not carbon)
cheers
ran87
Message  professeurhammond le Lun 20 Avr - 13:23
Ok thanks !
So how did you set the 12V conversion ?
Does it work properly ?
Cheers,
Message  ran87 le Lun 20 Avr - 13:26
actually i bought the bike already set to 12v. luckely Wink...
don't know how it was done. Sad
ran87
Message  professeurhammond le Lun 20 Avr - 13:31
Ok, so I guess you still use a battery ? Is it 6 or 12V ?
Message  ran87 le Lun 20 Avr - 14:09
Yes, i still use a battery. Its a 12V battery.
ran87
