Blinker replace with mini blinker
Message  ran87 le Mer 18 Fév - 11:18
hi there
the big standard honda blinkers have just one cable. i saw that all of the mini blinkers have two separate cables. do i just have to connect one wire with the frame or how is this supposed to be done?
thanks for your advice!
ran87
Nombre de messages : 11
Re: Blinker replace with mini blinker
Message  Invité le Mer 18 Fév - 12:28
Hi, Do you mean this???
If it is there are two pins also! ad it's a standart Honda.
Pascal Wink Wink
Message  ran87 le Mer 18 Fév - 12:44
no, i mean this:
on the mini blinker-indicators are always two wires. i am not sure where to put the second one.
ran87
Message  eldorado le Mer 18 Fév - 12:47
Salut Bosco !
Je pense que le gars s'est trompé de forum...
Il veut faire dans la customisation, pas dans la restauration.
Message  Invité le Mer 18 Fév - 12:50
Yes!!!!! ok, it's not a problem. On Honda, the two wires are ; 1) a blue wire or a orange . 2) a black wire which is the ground wire.
On yours blinkers, ther is only one wire, the ground is made by contact of the blinker on the frame.
Pascal Wink Wink
Message  Invité le Mer 18 Fév - 12:52
Salut Eldorado,
C'est ma foi bien possible...en fait il ne comprend pas pourquoi sur les repros il ,'y a qu'un seul câble qui sort des clignos... c'est pas grave, la masse est faite par contact des clignos sur le cadre... Wink Wink
Message  ran87 le Mer 18 Fév - 12:57
okay, thank you bosco!
as i tought it goes on the frame. so i will go ahead and buy this blinker-indicators Smile.
you helped a lot!
i will show you guys the bike in a few days.
cheers
ran87
Message  Invité le Mer 18 Fév - 12:59
OK, great!! So I wait for your pictures!!!
Have a nice day,
Pascal Wink Wink
